Gaggia Classic water res tubes
5 reading
4.6K views 6 replies 5 participants last post by  omegabri
Hi all
Just ran the Gaggia descaling fluid through my classic, as my routine cleaning schedule. I happen to notice that the 'longer' tube that hangs down into the water reservoir has some slight discolouration inside it, toward the top (above the usual water level), before going up into the machine.
Out of the two soft rubber tubes (one long, one shorter) I'm not sure which one directly feeds the boiler cylinder, but thought it best to replace it, if it's possible.
Anyone done this before, knows how, and/or even knows if it's possible to obtain new tubes!?
Or does anyone know if they can be taken off and cleaned through with anything safely?
Thanks guys
Bri..
#2 ·
Long one feeds the pump, short one is the return from the OPV
Discolouration is probably just scale, etc. and you could remove it and clean it - or just replace it. You should be able to get something suitable from an Aquatics centre I would guess, or if you really want Food Grade then try eBay.
#7 ·
Cheers guys. I'll wip 'em off and have a tinker at cleaning them
Bri..
