QUICK MILL CASIOPEA SOLENOID VALVE IS SHORTCUTTING
Hi
Recently I did a small renovation to my machine.
I replaced the steam pump, the safety thermostat and the solenoid
when I power on the machine and before activating the pump, the fuse burns.
I tried to disconnect the solenoid, put a new fuse and power on again. this time the fuse did not burn.
Im not sure whats causing the problem.
could be that one of the wires is not in place...
does anyone have a wiring diagram of this machine? any idea what could be the problem?
Please, don't use all capital letters on thread titles ūüė쬆
Edited by MediumRoastSteam
Are any of the insulation shrouds on the connections broken allowing the live terminals to touch the boiler / case ?
A photo of the inside would be helpful to see the connections.
50 minutes ago, Assaf Aman said:
Apologies for the capital letters...didnt know its not allowed.
I will take some photos and share
No one is disallowing it. It feels like¬†something is SHOUTING AT ME! ūüėȬ† - just etiquette and convention, that's all.¬†
understood and respected
Here are some photos.
Your thoughts are appreciated
On the lower / last photo there is a bare connector (blue wire) which looks as if it could be touching the adjacent pipe fitting and close to capillary tube coil. I will look further.
Using tape on terminals is not good, as the machine heats up the adhesive melts and the tape falls off !!!!
Buy some flexible shrouds  and work onto connectors.  If you leave the tape you could / will have problems at a later date.
Hi
I checked...Unfortunately it only looks like it because of the photo perspective.
The connector does not thouch the pipe fitting (actually its a few centimeters above it).
It was a few milimeters from the coil...but not touching...I pushed the coil away just in case.
As for isolation, you are absolutely right. I have a shrinking isolation which Ill use.
Sad for me, no success for me yet with getting the machine to work
√ó
√ó
