Hello-
I'm new here and struggling somewhat. I would appreciate some experienced assistance.
Using a sage Duo Tempo Pro and a Magnon Specialita.
 Using Cloud Coffee Gishwati Beans
Bought a tin of Illy Espresso ground to get a sense of what a good grind size would be- and worked to get very similar from Specialita.
Sage 58mm basket- 16 grams of coffee fills basket when tamped level using their tamper and as specified to be level with top in instructions
Timed extraction from turning switch on machine of 30 seconds.
Yield is not 32g as expected but 60- tried multiple times- with this and getting same result
Coffee is weak and lacking depth and that is clearly too much liquid?
What are the variables seasoned heads would suggest I tweak here to get a better result?
What am I missing?
Thanks in advance!
Edited by Beanthinking
duplicate
Fine enough to get the ratio out that you want. As simple as that. It will vary according to the bean you are using and when close to correct most grinders need very very small changes to correct.
Don't run the pump for 30s specifically. Run it for the amount of time that achieves your target ratio, allowing for a little run-on after turning off the pump, so you actually end at your target weight.
I'd aim a little longer than 1:2, more like 1:3 to 1:4. This will be weaker/less intense than say the Illy, but follow the changes in grind settingand how they affect the flavour balance. You can also use a little more coffee dose, say 18g?
Duo temp pro has a 54mm basket, not 58mm.
