Rocket Appartamento - Noisy pump
Well it seems I'm only posting issues at the moment! But anyway since getting the circuit board replaced the machine it's gotten significantly noisier. Clankly/like a bad car engine. Having done a quick google it seems like there would be two culprits
1) Boiler pressure is too high...(this wouldn't have changed since purchase (4 years ago, though so striking that one out)
2) Pump is shot and needs replacing.
The machine works fine and the coffee comes out as expected so any help would be great.
thanks
Saj
@GengisKhan Or something is now touching inside and causing noise. It's much more likely, than the pump being faulty.
Do you have a video of the noise.
Sticks and Stones, sours…or rancid (horrible). Quakers hide until roasted, pick em out and flick them in the bin. Life is too short for bad coffee
Sounds like a vibration issue, something's touching....or loose and vibrating. Pump sounds good
  • 5 weeks later...
