Hi, I have a fault on my Gaggia Classic:
From stone cold (i.e. first brew of the day) I can prime the machine and water comes out of the group head just fine but then once the machine is warmed up no water flows from the group head, I do however get steam from the wand if I switch the steamer on.
When the pump is working normally (when cold) it sounds fairly loud as it should be but when not working (when warm) it sounds like a muted hum.
The machine has been descaled several times and I have changed the CEME Solenoid for the better OLAB version but this has not fixed the issue.
Any advice greatly appreciated.
