BaristaofBards
Article - lower pressure and coarser grind for consistency
https://www.beanscenemag.com.au/espresso-reproducibility/
Just read the article from above which I thought was interesting.
I'm new to the game and have a gaggia classic. I understand the pressure can be adjusted down to 9 bar. Is this the lowest?
If you have adjusted your pressure, did you change your grind setting?
I'm sure this is old news to many but it's fairly interesting to a newbie. Another variable to get a handle of!
The brew pressure can be adjusted to whatever you chose, max approx 15 bar minimum whatever you chose.
I would suggest you check and set to 9 / 10 bar and stick wit this until you are familiar with the use of the machine, adjust one variable at a time.
The grind setting will vary with type of bean, roast and age of bean AND the weather= hot humid hot dry.
So many variables.
There are no fixed numbers / grind settings,  old / stale beans are dry= the water flows through quickly,
Fresh beans need to be rested after roasting 5- 10 days depending on beans.
It will also depend on the type / quality / condition of your grinder.
Weigh the ground beans into the PF, work initially on  twice the weight of coffee liquid from beans
Ie.   18 gms coffee.  = 36 gms liquid.  in 25 - 30 secs.  adjust grind to achieve this
Lots of reading in earlier posts'
