jimbojohn55
Pimp an 86 Brass Pav Pro
Ok so in the age of lockdowns and mindless rants on the forum I thought it was about time to impose another over detailed pimp.
1986 Brass Pav - never been restored or serviced - not in great condition but I've seen a lot worse - so on with the mindless condition details¬†ūüĖē
  • Like 7
Short boiler cap has a brass insert for the screw threads
  • Like 3
The lever is close fitting with no waggle !
  • Like 4
The brass pavs are not all brass, in particular the base is brass plated steel so takes the most damage. Im probably not going to do a total refinish on this one as it starts to get hideously expensive, for example a replacement base would cost 180 Euro !!! so the existing base will be pimped
  • Like 5
Hmm after much thought about the music to pimp by and having just heard the Charles has corona I think I will go with
  • Haha 1
Curious about how you are going to approach this one as I have the exact same problem with a chrome plated base although mine is way worst than this
Looking forward to seeing this as all your previous refurbs have been top drawer.
ok so on with the strip down and a light descale
  • Like 3
The element on these has a copper shroud , in place to promote the flow of heated water circulating around the boiler
  • Like 4
So the pressurestat  on these is a quality bit of kit, and engineering, I knew that the pstat was not working and as suspected on closer inspection it was not possible to blow air through the pipe, a quick wiggle with a pressicion tool that took several house to make sorted that.
I took the pstat apart just to check the microswitch was working, which it was.
  • Like 4
So now the neighbour has stopped singing and holding a candle on their balcony I can concentrate on more important things FFS¬†ūüôĄ
The pressure gauge has a cracked face and some discolouration of the surround, so tapped off the bezel using a small hammer and a flat washer to  work against the bezels edge all the way round.
Then pop in a replacement glass and holding the gauge face down force the bezel back on, after cleaning up the parts.
  • Like 4
  • Haha 1
On with the pimp, group strip down,  pass me a shovel
  • Like 3
  • Confused 1
And the prize inside is of course a rusted in steel circlip
  • Like 3
Yay refurb thread
Love the look of the brass pav..... Looks even more stream punk than usual
Sent from my SM-G960F using Tapatalk
Gaggia Classic Chrome - Mignon Specialita 55
The rusted in circlip actually proved quite straight forward, with a soak in penetrating oil overnight and prying it with a scriber and screwdriver  it came out quite easily.
next popped the group, piston and shower screen into a jug of pulycaf for the initial clean up.
Edited by jimbojohn55
  • Like 4
Pfft practically a brand new piston that ūüėČ
Nice work :)
1995 'Coffee Gaggia' with full Gaggia Classic conversion, DIY PID Controller, OPV set to 9bar, Silvia steam wand, Botomless PF, VST 15g Basket, Motta 58mm Tamper and Ascaso I-Mini grinder
On with the teardown, removing the lock ring with a few careful taps and a three leg oil filter wrench.
this allows for a closer look at the discoloured brass, much of it appears to be an oxidised layer under the clear lacquer.
  • Like 3
Can you make it look like this though
  • Like 3
AKA Toffee chips
√ó
√ó
