GeordieGeneral
Gaggia 2019 timeout solution (maybe)
!!Please read the above link first!!
I've just swapped the brew switch and the power switch over and it works exactly like in the link above.
I am going to get a smart plug tonight and do some testing.
I.e. when the smart plug has switched the machine off after my morning coffee then on again at lunch will it revert back to the auto timeout of 30mins or is it still disabled.
Edited by GeordieGeneral
As I mentioned in your other thread about this, I expect to have a proper and pretty simple / reversible fix for this - without swapping buttons around etc. and keeping the machine's usability and functions the same as standard - within the next few days.
I'm also working on a cheap and easy OPV fix as well.  Will probably end up offering both as a simple and cheap "Fix your Classic 2018+ here" kit - OPV to 9 bar (and perhaps 6 bar optionally) and disable timer in a cheap combined kit.  Makes it into a much better machine!
Watch this space...
  • Like 6
Fantastic news, I think/hope 🤞 this shall suffice until you release your mod.
!EDIT!
smart plug works a treat, shall persevere with keeping the brew switch pressed while brewing until MrShades releases his mod.
Here you go:
