StevenG91
Restoring Italian La Pavoni 1980ish
Okay so I was impulsive as Ive always wanted one of these machines and picked one up at a decent price on ebay. Being a complete Newby to these machines can anyone point me in the direction of instructions for complete tear down and service. My main question is that this comes with Italian mains lead and plug does anyone know how easy it will be to change over to UK with earth wire. Many Thanks
Edited by StevenG91
17 hours ago, Nopapercup said:
This model is from the late 1970's and like most pavs, fairly straightforward to refurbish. Here's a thread of the two I did
also check out Francesco's site for all info and he also supplies parts http://www.francescoceccarelli.eu/index_eng.htm
Thank You, I'm a complete Newby with these and my knowledge is lacking and this will certainly be helpful. Ive just read the entire thread and don't know wether to be excited or scared haha.
Edited by StevenG91
These where my first attempt and the only difficulty was removing the element but if yours is working and you're not painting the base then you won't need to.
If you're changing the other wires than take a few photos first and copy when swapping. If all is working than maybe just use an adapter for the plug and just descale and change the gaskets.
If it isn't leaking at the bottom and you're NOT painting the base, then all you need to do is change the group head gaskets and move on. Takes, maybe, an hour max. Only thing close to a special tool is a set of snap ring pliers that you can get pretty cheap. No need to be scared. You'll see how simple these things are when you get into it.
Here's a video of the group only rebuild.
Sorry I should have made myself clearer in my post, I'm currently waiting on it arriving from Italy. I just want to try and get a head start on it. I have no idea about the state of it other than from the pictures. I've been assured that it turns on fine. For safety reasons would it be wiser to completely renew the wiring and change to a UK plug with earth wire or if its not broke don't fix it as they say and just get an adapter for the plug. I have no electric experience what so ever and would have no idea where to start with any sort of rewiring (I've even watched the Orphan espresso video on wiring but alas I'm am an electrical idiot). With regards to the element, does this not need to be removed to put a new seal in? I'm assuming this machine hasn't been touched since the 70's. Sorry for all the questions.
Thanks for the Video! This is extremely informative. I'm just waiting on my machine arriving and then ill be able to see what state its in.
It could be fine or a mess which you won't know until you get it. If you don't feel comfortable taking on the electrics it might be worth getting someone like Frank at https://www.ferrari-espresso.com/ to service it for you.
Well hopefully it should be here by Tuesday. I'll keep Frank in mind if I decide to get It rewired. I'll post some pictures of the machine when it arrives ?
Got the machine today dated 1983. Chrome is pitted, water has been leaking underneath the base. Could be In worse shape I suppose. Excuse the photos of my food haha.
Looks like a good project.
They are very easy to take apart and put back together again.
I managed mine with standard tools.
I didn't really do much of a write up on mine as I'm not very good at documenting stuff, my advice is take lots of photos before you disconnect anything. Mine was a bit easier as my wires were colour coded.
Gear:   Gaggia Classic, La Pavoni Europiccola, Niche zero.
At work:  Aeropress, Porlex mini.
Could I get a picture of your switch?
My switch is I think the same as yours, 2 separate switches. Top one switches it on, the bottom one switches from 1 element to 2 elements. The only difference is mine has a plastic cover.
Thanks, I'm debating wether to do it myself or get it serviced and rewired by a pro. Its got an Italian mains cable and the interval wiring was soaking. I believe I could do everything else myself but I have no electrical knowledge and don't want to botch the electrics so I'm in two minds about what to do.
I would be inclined to get the wiring done by a pro.   You could do the rest and then just send it off to get the wiring sorted.
Getting the electrics wrong and mixing it with a metal machine and water seems like a disaster waiting to happen.
Edited by GrowlingDog
Spelling correction
My thoughts exactly.
Mines currently in bits as it tripped the electrics 10 days ago & not being able to see what was wrong I had my electrician look at it last night after he fitted new lights for us. Turns out the mains cable was burnt out & I'll get him.to fit the new one.
Gaskets etc are easy to fit but electrics are best left to the experts.
A machine, a grinder & some beans
That's exactly my thoughts. I've emailed Frank at Ferrari espresso for a quote for fixing electrics.
Your local electrician should be able to do it.
Yes, I agree with that.  There is nothing complicated about these for an electrician.  It’s two switches and two elements.
worth asking a local appliance repair person as it will probably be much cheaper.
I'll definitely consider doing that.
The machine looks really good as it's probably totally original. For peace of mind get the electrics done by a professional. Frank at Ferrari is very reasonable but each time you post it there's a risk of damage.
These guys I think are based in Scotland https://www.theespressoshop.co.uk otherwise as the others have suggested ask a local sparky.
My dealings with theespressoshop have been really positive.
I’ve only used them for parts but they were really helpful when I couldn’t work out which bits I wanted for my machine.
They sent me all the correct size bits really quickly.
With help from this forum and a bit of work and polishing you will end up with something wonderful.   I still just want to look at mine and not get it dirty now it’s finished.  It’s worth the effort.
Looking forward to seeing yours when it’s finished, can’t beat a shiny La Pavoni, even my wife likes mine now.
  • Like 4
