Nicknak
Profitec E61 Flow Control Device
Having been tempted by the Lelit profile control device at £252 I was kindly pointed in the direction of Bella Barista who have started stocking the Profitec one at £179 plus £6 postage . It arrived within a couple of days . It arrives in two pieces the flow control unit and a pressure gauge for the group . There are no instructions and no washers for the gauge are included . However fitting is a doddle 👍. The unit comes in one piece , so unscrew the existing Mushroom and replace with the unit . I put some grease on the mushroom o ring on the bottom and a little on the threaded part .
I did speak to Bella Barista about the washers for the gauge which are mention on the website . It does not come with any and they say not to use the existing one under the E61 bolt . Their  advise to use ptfe tape and use only hand pressure to nip it up in position was followed. Waiting for it to warm up to check for any leaks and have a play .😎
It took more time to give the machine a quick polish for the photo 😬 than to fit it 👍
  • Like 4
It is looking very shiny but . . . What do you reckon? Pleased you’ve fitted it?
  • Haha 1
Yes pleased I fitted it .. Time will tell I suppose if it gets used much . The Profitec knocks out good shots constantly ( am I now going to mess that up 😂) But I have read a little on slow ramp ups , pre infusion etc and wanted to play .. The PTFe on the gauge has worked with no washers and no leaks from anywhere else ..👍
I do look after my stuff , see 😂
  • Haha 1
Things just got exciting, as far as I can tell from my rocking chair... there's nothing to it - but to do it!
now get on with paddling about and forking tell us more!! Will ya?!
  • Haha 2
Howdy 😎, how is that banjo practice going ...
Well the first cup was fully open , just to get a look at how the things looked normal like .. I then ran water through the spent puck fiddling with knob , watching how it affected the pressure gauge .. Might go and try a 6 bar shot with a little perfusion 😬
Nice conversion!
A good one to try out is the straight 6 bar shot. It's kinda become my go to profile with most dark/medium espresso blends.
Mmm reckon it's compatible with a Rocket Giotto?
21 minutes ago, lake_m said:
Nice conversion!
I just sort of tried that , didn’t go too well .. A little more practice required 😂.. Very small adjustments needed as opposed to my let’s have a guess there ..  The spent puck is so much easier to work with 😂😂😂
I would quite like a video - I will get some popcorn in ready 😊
  • Haha 1
  • Sad 1
It should do if Rocket use a standard E61 ..  Both this and  the Lelit one fit other machines . Espressounderground are listing Machines they or customers have found don’t fit .. A check on the internet might reveal more .
It will be sometime before Videos are released .. It will need intense concentration on my part to overcome my inadequate  efforts .. 🤯😂 . ... Plus I can’t steam milk at the same time .. Might have to try the glass method 😂
  • Haha 1
I sympathise...us men can only do one thing at a time and even that can be problematic
  • Haha 2
Well on the second attempt ,the pre infusion didn’t go too well so I sort of ignored that but managed 6 bar throughout . 🥳🕺.. The amount the knob was turned was minimal .. So I don’t know what the other full turn left might be used for 🥴 ..
Have you had any more thoughts on this @Nicknak
I'm looking to add one to the minima but its a toss up between this and the lelit one. The handle on the lelit one looks a lot nicer but its £20 more and a little more involved to install.
Are you still using the profiling shots and what has become your go to profile?
 Still playing with it really , but it  adds a bit of fun to the whole process ..  I have found that the valve now has a better range of movement and needs more of a turn to go from off to full on . I wonder if it had a minor blockage after I fitted it .
I used it with a decaf , which had a very slight back ground taste which I can only describe as stale . When I used the flow with a 10 seconds at 2bar on the gauge then a really slow build up . The stale taste which was just there ,just noticeable went .
I have currently got it set in one place ... It takes about 10 /15 seconds to get to 2 bar then rises very slowly and generally sits at 6bar ..This can be affected by the grind and distribution ..
The knob on this can be turned fully all the way around to both closed and fully open ,which I like ..
Have they reduced the Lelit one , The full kit when I got mine was a lot more
Not sure as every site that sells its seems to use different pictures and different descriptions that don't match half the time!
Seems to include the paddle, pressure gauge and the gubbins to actually control the flow based on BBs description.
Would you say overall that its improved the quality of the coffee you get from your machine?
You probably saw the write up and vids, but in case you didn't..
https://coffeeequipmentreviews.wordpress.com/2019/08/30/acs-minima-with-lelit-flow-profiling-kit/
with the paddle all the way to the right you can have more flow than from a standard gicleur, you need to be careful not to move it too far to the right when profiling but also mindful of the 9 bar pressure or whatever with insufficient flow problem that all these valve systems can give.
The first post here I mentioned the places and the prices I worked on .. I haven’t looked since ..
BB were quick and easy to deal with ..
It certainly worked for the decaf .. still trying to make my mind up for my normal coffee .. Plus a new grinder in the mix ..  I think I am getting sweeter , but I was loving what I made before . My wife doesn’t drink the stuff so have no one else to test it on .. Visitors were and are happy . I am considering changing back and forward by taking out the flow valve all on the same day .
Yes thank you , it was that which prompted me to look into it .. As I have a Profitec 700 I decided to go with their one .
Edited by Nicknak
Ah, the comment was meant for @mctrials23 who wanted it for a Minima. I wasn't sure he was aware I had already installed it on a Minima.
  • Haha 1
Sorry to ask - I don't want to interrupt this thread with another topic - but what do you mean with the "insufficient flow problem"?
I am just about to by a Lelit Bianca and as I am complete Espresso Newbie I thought at the beginning I could just put the paddle to the far right (and adjust the max pressure to 9bar) and use the machine like any other E61 machine or maybe adjust the Paddle to a position with will result in 9bar (and leave the max pressure of the machine at 10 or 11).
Will this cause any problems?
Johey welcome .. on the Profitec one which I have I just make a metal note . I’m using lower flow currently so not a problem for me I guess . There is a fair few that have the Bianca so I would make a new thread and ask away ..
