Beemer
Crema distribution problem
I use a double spout portafilter and am finding that the crema always is greater from the on the left spout.   Otherwise the pour is equal in volume on both sides. Is this a common thing,  what causes it and can it be corrected?
Ian
Izzo Alex Duetto III + Mazzer Mini E Type A (time adjusts on lid)
Ian
Does it effect taste ?
Is your machine level? I mean properly level.
If the machine was not level than the pour would be unequal which is not the case except for the crema.
You could tilt the machine a bit (put something under one side or later adjust the feet) and pull a shot to see if it makes any difference.
Have you tried tamping marginally harder on the lesser side?
^ This. Check in all directions with a spirit level at the grouphead not the machine’s shell. Also take a look at your portafilter. That may not be perfectly symmetrical and so have an inherent bias.
It’s also worth checking there isn’t a small build up of coffee inside the portafilter spout, even if it looks clean try giving it a proper clean and poke through the spout with something then try it again.
