jonluke1970
Manual grinder for V60
I need to buy a new manual(travel) grinder for making V60’s. Are there any filter specific manual grinders available. Which grinders work best for filter?
Most manual grinders work fine for V60.
At the cheaper end (£40-£60) you have Rhino, Porlex & Hario Slim, these have ceramic burrs and take a relatively long time to grind a dose, doses over 20g can be a real chore.
Zassenhaus make a couple such the Panama (holds 20g) and Quito (holds about 40g) in the £50-£80 range. These work OK for V60 but don't go fine enough for small immersion brews (Aeropress/Clever/French press), OK for larger immersion brews and if you use the Clever as a pourover.
Made By Knock start at just over £100, buy from a reseller, not direct. Compact & intuative grind setting.
Then from ~£180 upwards you have Lido (large, but Lido 3 & Lido E/ET are light), holds about 60g. Commendante's are also in this price range.
Kinu cost a little more.
