Bastos80
Rancilio Silvia grouphead top screw, and pressure measurement point
Hi everyone,
I'm just curious, what is the purpose of the screw on top of the grouphead? Could it be used to monitor temperature, or maybe pressure?
Temperature is already assessed/managed by MeCoffee, I wouldn't go as far as monitoring the delta with groupehead temperature.
On the other hand, I'm considering adding a pressure gauge. I don't want to place the measurement between pump and OPV, as it only measure the OPV setting. I am considering measuring on the steam pipe, I could monitor a manual pre-infusion by the use of steam knob... Or maybe this grouphead screw?
Thanks in advance!
Purely for manufacturing reasons. They drill a water path into the grouphead (instead of making a complicated casting form) and afterwards have to close an unneeded hole. This picture should explain it.
The position is not advantageous.
  • If one wants to get as close as possible to the real temperature in the filter, that point will not do. For a good measurement, drill straight down through the grouphead and through the shower screen screw. A 0.5mm thermocouple inserted that way (installed with a compression fitting) ends in the coffee. Example: https://www.kaffee-netz.de/threads/installation-eines-temperatursensors-in-silvia-bruehgruppe.111093
  • For pressure measurements, it does not matter (noticeably) where the pressure sensor is installed at the boiler. It's not necessary to get as close to the filter as possible. It's easier to install the pressure sensor - which is quite long if installed with plug - at another point, e.g. with a 1/8" T fitting at the boiler input port.
If you are interested in installing a pressure sensor, take a look in the appendix "Pressure sensor installation" in the installation pdf of the leva! firmware. leva! adds pressure profiling to machines.
Edited by dtmr
