2cups
Backflushing, and pump(?) issues
Hi all,
I've stripped down, cleaned, de-scaled, and replaced the seals on a rather neglected 2004 Gaggia classic. Certainly a voyage of discovery. Now it's back together, having a few issues (which may be related):
  1. Leak at pump elbow valve. I have used large quantities of PTFE tape, as per various other threads on this, which has improved the situation. Now it still leaks, but only in steam mode. I think I may have stripped the plastic threads on the pump through over-zealous tightening. Any way I can get myself out of this, or is it a new pump situation?
  2. When backflushing, I only get a few drips of water returning back to the tank. The pump goes quiet after a few seconds too. Is this normal?
  3. Very soggy, watery puck, when pulling a shot (ablit with pre-ground coffee).
Any help greatly appreciated!
Paul
EDIT: Thought it might be worth mentioning that I disassembled and de-scaled the solenoid. Also, when finishing backflushing water is ejected down the tube into the drip tray, as you would expect.
Edited by 2cups
New pump ordered - the EX5, with brass fitting. Which should hopefully limit the scope for numpties with no mechanical sympathy (ie, me) to cock things up.
Hiya, I've just stripped my 2007 classic and sorry to hear you've had some problems - mine was also quite neglected and I made sure I replaced all the seals etc and fingers crossed no problems as yet.
Stripping threads is always going to be a risk - you never quite know how tight to go until it's too late 😖
Hope everything goes well with the pump replacement
Cheers Amanda. New pump in, no leaking, and (funnily enough) backflushing a whole lot better!
