I have a 9 month old Piccino which is only used for 2-3 coffees per day; I always use Volvic water. When I switch it on in the morning it goes through a filing and heating process, then it vents steam from a valve behind where the steam wand joins the upper part of the machine. This can last from 1 to 5 minutes before it clicks off and all is well. Over time this steaming time is getting longer. Any suggestions of what is wrong and how to fix it. Any advice would be much appreciated.
Yes it is from inside the machine so I will try your suggestion, many thanks.
Related Threads
Coffee Forums
890.8K posts
39.5K members
Since 2008
A forum community dedicated to coffee enthusiasts. Come join the discussion about collections, retailers, beans, grinders, brewers, technical maintenance, models, styles, teas, reviews, accessories, classifieds, and more!
