jimbojohn55
Pimp a 1962 Gaggia Minibar Orione
Last few bits of chrome to clean up last night, this it the elbow between the lever and the group, the two strips of metal bent around  it held on witgh two screws are part of the lever cocking mechanism , ahem cough
  • Like 4
keep calm and grind flat
and after clean up
  • Like 5
Also solved the heat resistant wiring issue, originally these machines had wires that were threaded with ceramic beads - not exactly IP rated or easy on the eye.
the solution is 1.5mm Sq oven wire only about £1.80 a meter for each colour. Ive also got some silicon coated braided fiberglass cable protector that I will use over it
Edited by jimbojohn55
  • Like 5
That should work nicely
16 hours ago, jimbojohn55 said:
and after clean up
Not sure if that is shiney enough Jim 😁
  • Haha 1
AKA Toffee chips
Jim you need to treble your prices for this one. 😂😂😂
You know where you can take it ! 😬
tbh I didn't buy it or pay for the chrome, and its been fun to do...………….also its not back together yet 😬
  • Like 3
  • Haha 1
So nice of toffee chips to gift you a knackered machine & pay for the chroming too.
  • Like 3
Back to the wiring having conveniently pulled a back muscle while tiling the kitchen floor haha
The original grommets on the 80's pressurestat had perished but were an odd size eventually I purchased a box of mixed size blind grommets (make your own jokes up)  and one of the sizes was spot on. This enabled me to punch a hole in each that was the right size for the different size cables
  • Like 5
To finish of the cables neatly - because why not, I crimped some old style ring terminals on them and then added a small piece of heat shrink
  • Like 4
did you consider buying a box of Wallaces as well?
  • Haha 1
One of the issues I noticed when this machine arrived was the lack of  earthing wires to the various parts of the machine - now on the basis that electrical safety has bcome along way since 1962, I though it only reasonable to add some if there is ever to be another lever day.
  • Like 4
For the main power wires to the element its probably overkill  but ive housed the oven grade wires in a heat shield - silicon coated braided fiberglass
  • Like 4
So if there is ever an electrical fault anyone touching it gets to lever 'nother day?
  • Like 3
the postie has a hernia, but look at what he brought 😀
remember these
Welcome to the age of chrome ……. damn their shiny
  • Like 5
Ooh pretty.
Very nice work getting the nibbles out.
Let’s hope the cocking mech matches the quality of that chrome @jimbojohn55
AKA Toffee chips
Do you remember what you were doing in August? I do it was the start of a lengthy course on boiler repairs and seals
some of the issues
Pin holes in a boiler seam, various repair techniques - trust me you need to get it professionally brazed preferably by an old bloke smoking a roll up at the same time
Boiler gasket materials - the benefits and types available
preparation of mating surfaces - its a thing honest , in the 1960's Gaggia Barcelona workshop, lets just say they did not use quite as fine a tolerance or surface finish as you would hope for, but it worked for them
Gasket dressing  - its a thing!
point of all this was a lengthy learning experience, but worth it
some of the process
  • Like 4
Interesting challenge taking photo's of chrome and trying to avoid reflections
front panel back on with the pressure gauge fitted then the steam arm and valve knob
  • Like 5
A nice detail of this build is the tiny shelf which bolts under the sight glass, to help reflect the light, I left this attached to the front panel by accident when it went for chroming and each component came back perfectly chromed including the bolt heads and nuts!
  • Like 4
What a happy mistake!
took me a while to make a shelf out of the batman I've been looking at, initially...
Quality job mate!
Are you goung to finish her before next August?
  • Haha 1
Sent from my moto g(6) using Tapatalk
  • Like 3
