If my grinder is currently set for an 18g VST basket, will that grind work for a single dose basket (eg. the stock Gaggia one)? My wife prefers the smaller single shot in the mornings, whereas I am on the double. Switching between the two is proving difficult, with the double dose grind setting choking up the single basket. Is that just to be expected? All input and suggestions gratefully received!
I use a 18g VST most of the time & while the grind for my 7g LM Strada (made by VST) & 41mm tamper is similar, it still takes a bit longer to hit the same ratio.
As my dad prefers the 'traditional' longer ratio of an Italian espresso it can be longer still. I really should get a 58-41mm dosing ring so I can tamp the single easier & maybe a touch lighter to compensate.
Related Threads
Coffee Forums
890.8K posts
39.6K members
Since 2008
A forum community dedicated to coffee enthusiasts. Come join the discussion about collections, retailers, beans, grinders, brewers, technical maintenance, models, styles, teas, reviews, accessories, classifieds, and more!
