Recently got the silvia steam wand upgrade from happy donkey. While fitting it i took a closer-than-usual look at my water reservoir and it was pretty dirty, as was the silicon tubing. I'm concerned that it's fungal growth. The shorter tube is easy enough to remove and clean. Is there an easy way to disconnect and clean the one that connects to the pump? I've shoved a pipe cleaner down/up it as far as i can but ideally the whole thing needs to be taken out. Thanks
Hi, you could with taking the tube out & cleaning inside with a cleaning brush like the ones used for cleaning the water tubes on hydration packs, new silicon tubing is another alternative, it's not expensive and the Classic isn't hard to take to get its covers off to get access
Fracino Classic-Brasilia Portafino-Isomac Tea and Millenium-La Pavoni
Cellini and Europiccola Pro-Gaggia Titanium, Classic, Colour, Cubika
Gene Cafe Roaster-Mazzer Super Jolly Doser-Rocky Doser
Ebay is the place for silicone tubing. I bought 1m of FDA approved 6mm ID and 10mm OD for mine for about £5 delivered.
Glad someone could remember the dimensions needed. Getting the precut OE silicon tubing is definately a waste of money.
There is always someone on here who carries in their head exactly the information needed, that saves people loads of time and money. I love this place for that.
___
Eat, drink and be merry
Thanks. I took the top cover off to get a better look. The tube that connects to the OPV is easy to take off and clean, but the other one sneaks in under the pump and is pretty difficult to see or get to. I suspect that there isn't a quick fix and that I need to actually spend some time and effort dissembling it to get the tube off. I suppose it depends on how much I really want pristine tubing.
There is a solid spring bar which holds the flexible mounting to the pump bracket. Unclip that and the pump and flexible mounting slide out from the bracket allowing easy access to the push on pipe connection to the bottom of the pump. Possibly take some pictures before removal so you can see how it goes back together
    Advertise with Us
    Get your 2019 Supporter Badge
