alex68
a motor cover plate for Royal
1mm aluminium sheet can be cut with most saws ( although a fine hacksaw is much easier) - you can even sand the edges flat (although a metal file helps)
buy an offcut big enough off fleabay
and become a 'Fabricator'
Top hat / tie are optional
[ATTACH=CONFIG]38608[/ATTACH]
Cheers jimbojohn55. Will try that. Looks to be under £5. Is the fudge funnel cut out as a U shape or bent somehow like the oem above. How did you fix it in place as I currently use sticky pads for the card.
this has all the basic info -same principal as the SJ mod - The top hat helps by the way, :whistle:
https://coffeeforums.co.uk/showthread.php?39641&p=518635#post518635
edit - the major version
https://coffeeforums.co.uk/showthread.php?40402-Pimp-my-Major/page11
This is mine on my Major.
The bottom of the plate on mine is held in with 2 screws.
I used the official Mazzer Major motor plate on mine.
Edited by urbanbumpkin
Thanks. I followed this a year ago and have forgotten about the plate upgrade.
Do you happen to remember if the major plate has the same dimensions as the Royal?
I think it is as the doser is the same size - I would do a funnel first then check with a cardboard template.
Yep. Just checked 96mm and max of 120mm. I guess height is dependent on the funnel position.
Would my dremmel cut the curve on 1mm aluminium?
easily :good:
easily :good:
Edit what you might have to do is cut a series of straight lines and then use a dremil metal file or sanding drum to file out to the final curve
I think I might ask the powder coaters who are doing the Royal case to do this in black gloss to match too.
Just ordered 1mm 120mm 96mm pre cut for £1.50 delivered. Bargain!
Edited by Badgerman
Where did you order from this pre cut plate ? Thanks
:coffee:Lelit Bianca, Mazzer Royal
It’s fine. The missed my comment and sent a stock 125mm2 so had to cut both ends and the curve. It’s harder to do to make straight with such small amounts to cut off. So I am thinking of ordering some more and ensuring they cut it to order with a proper cutter.
Any comments if should get it done black with the case or keep it silver like the funnel, neck and forks.
061ff57615e4e84fd7dd86076b55fd84.jpge4a131787d7ab6f584b5636ea4b9ef52.jpge8dc27d2c938e163ad37ba7a19c70016.jpg060f2bcb32c01234dd8581cdbb6e718a.jpg
It looks good. I'm browsing possibility to order stainless steel plate, as well. But probably it would be not easy to cut to size with Dremel machine?!
I used a dremel. It’s fine for the funnel. I think the outside edges are better precut or done properly. I have asked the seller if can cut 96 x 120mm for me to have a second attempt.
What size would I need for mazzer mini
not sure but do the funnel mount it up then measure, I suspect its the same as one for a jolly as I think the doser is the same size but im not certain
post 13 on - https://coffeeforums.co.uk/showthread.php?39641-Pimp-my-shelf-octopus-funnel-Mazzer-SJ/page2
post 24 for the size (possibly)
Edited by jimbojohn55
So I got the eBay seller to cut 96mm x 118mm for £2.50 delivered for new piece of aluminium.
Looks better, recommend to anyone with an octopus funnel if not done so.
bf256aca5b7d874b3444b21987a05872.jpg5d9d2587aecf4a98ed1c895c3734d53c.jpg0be89eb08b69c9f216e9581fc2f0fdf6.jpg
Anyone recommend doing the plate the same colour as the chassis. I am going with powder coating gloss black. In two minds about leaving the plate chrome looking to match the funnel.
If anyone wants my old aluminium back plate pre-cut (not as tidy as professional), happy to send on. Here are the dimensions for future reference too.
e181cacf98cc4f4536c707ec8be69ec6.jpg4e8e7001ad4e1f43121114a578fb6a24.jpg1b7164e75d4339cbbb7d3424b0dc0899.jpg
