ryanuptheroad
Reverse osmosis water in London
Recently moved from Edinburgh to South London and struggling with a solution for my dual boiler. I don't want to continue buying bottled water due to the plastic waste. Renting so I can't plumb in my own filtration system. I know a Brita filter just doesn't cut it in these 'ard parts. Can't find a shop that sells RO water by the gallon, except expensive high volume delivery services.
Was hoping to find a cafe that I could fill up a jug at every 2 weeks or so. Would be happy to buy a coffee at each refill to support the cafe. Haven't had any luck at the places I've visited so far. I appreciate it can be a challenge for them due to plumbing/liability issues.
Anyone know a cafe that might help me out, or can suggest a different solution to the problem?
Any help much appreciated.
I can’t offer any help with a supplier but have you read this thread about water. The later posts deal with an RO machine.
I used to produce my own RO years ago when I ran Marine Aquariums.
I don't think the setup was overly expensive, here is a link if it helps:
https://www.ro-man.com/shop/
Vesuvius • Hario VST-2000B • Distributor • Push Tamper • Niche Grinder
I am curious as to why a Brita filter isn't any good? We are in Herts with a lot of hard water, and have used jugs for years and now an under sink Brita filter, and have had no issue with scale on my Zafirro or my kettle
Which part of London are you in/would be convenient to go to regularly for the water? Might help narrow down selections
Spro === Compak E8 Redspeed / OE Pharos ---> The Rising Force Tamper ---> LR (IMS 35um + VST 18g) / Cafelat Robot Filter === OE Apex / OE Lido 3 ---> v60 (chemex papers) / Able brewing system / Aeropress Water === Osmio Zero
I think if it's working for you...stick with it.
Thanks for all the replies, worked my way through the other thread. I'm in Elephant and Castle. I've read a few pieces about Brita water not sufficiently protecting from scale problems. Starting to think that if I can't find a local place who are happy to share their water supply, bottles of Ashbeck will probably have a similar plastic and environmental impact to getting a Zero Water setup. When I'm in a more permanent home setup I can invest in a better system.
My understanding is that ro water needs things putting back into it for the coffee to taste right/better
One of the big brita purity quell should get rid of most of the things you don't want in your machine or the smaller BWT cartridges might handle a lesser demand if just for coffee etc
It's alot easier to take out everything & only replace what you want than to only take out the nasty hits. Even some of the BWT filters add magnesium back into the water.
Who said it, how was it tested, was it RO water used?
I knew I would find it in the end....
Particularly comments made from around 6:20 in the video about how magnesium and calcium enhance flavours
Ah, probably a good job the Osmio has a remineralisation/antibac cartridge using ceramic beads as the final stage to put Ca and Mg back into the water in small amounts....me I probably will pull it for a blank, but I'll see if it makes a difference.
