Raffaz
Melitta Barista TS issue
Just wondering if anyone can help with an issue i'm having
Basically when brewing a coffee the machine grinds the beans and then the brewing unit attempts to compress the powder, but it seems that it cant complete the full press and the mechanism stops just short, it then ejects the coffee grinds and stops brewing
I bought a replacement brewing unit to eliminate this and its doing the same, the machine makes a creaking noise when attempting to compress the powder
Has anyone experienced this or have any ideas?
Regards
Michael
Sometimes they can creak a little, a bit of silicon spray in the moving parts, or use it on a cotton bud for the slider bits. I don't think it's a problem compressing the powder, probably something else, especially as a new brew unit has not solved it. They have a little bean hatch thing that closes so it can completely grind out a portion without leaving crushed bits in the grinder. If you use beans with lots of little bits in (e.g. cheap coffee), then sometimes these bits can jam the little hatch in the hopper and cause a similar problem to the one you describe.
Are you getting any error messages?
Thanks for the reply
The machine doesn't generate any errors. It just stops the machine and gives me an option to restart, if i restart, then it grinds new beans again and then tries to complete the cycle again and fails
Cheers
Mick
Hi There,
I hope someone can help! I have a melitta cafe solo, just a few years old.
It has been cleaned, but water is running straight into the drip tray and a little coffee grounds appear in the tub also (in the drip tray) but no coffee runs through the actual coffee outlet.
When I clean it water will run through the coffee outlets so I don't think it it clogged.
I've seen online this may be the drainage valve, but I have no idea where to begin or what to replace- any ideas please?
Many Thanks,
Claire.
@DavecUK
