PottyMouthedBuddhist
Portafilter Stand for Scales
I'd like to buy a stand that will allow me to rest my portafilter on my scales so that I can accurately weigh the grinds. Something like this one from Decent Espresso:
https://decentespresso.com/portafilter_stand
But frankly, €33 seems a bit blooming steep for a simple bit of plastic, so does anyone know of any cheaper alternatives? Otherwise, if there are any 3D print fanatics out there looking to make a few quid, then I'd be very grateful for something like this:
https://www.thingiverse.com/thing:2808434
I use a glass ramekin bowl for this purpose, admittedly not as pretty as the ludicrously expensive Decent Espresso one you've found, but it does the job. Roll on the proliferation of 3D printing.
Vesuvius | Niche grinder | Mazzer Super Jolly | This week I shall mostly be drinking ... Foundry - Rio Magdalena, Colombia
P1: 2 [email protected]; [email protected]; [email protected]; [email protected]; [email protected]; [email protected]; [email protected] ('lever profile')
A lump of sugru or air drying clay molded into a half sphere. Press your filter down onto it and make an exact imprint of it.
Let the silicone (sugru) or clay set, paint it... or don't
Edit: could even make a mould of it and cast a few in resin. Should be able to knock a few out for common filters.
Speaking of ludicrously expensive...the acacia lunar comes with a rubber protection pad for the top work a 90 lip, to protect 1cm down the side.
If you tun the rubber pad upside down, it is just strong enough to support a naked PF for weighing.
It’s a superbly simply solution, the downside is the cost is a nudge more than Decent are charging, but they are exceptionally brilliant to use.
Personally I gave up weighing coffee in the porta filter. The mass of the filter (compared to 7-20gm) of coffee is so large you can expect large errors. I started using 50gm digital scales and a plastic rattle paint can lid to hold the grind. Tare out the lid, weigh the coffee and transfer to the porta filter.
Now I have a much better solution, I just got a 'weighing spoon' off Fleabay. There are several but this is like the one I'm using. A steal for £3.50: I use a white spoon exclusively for my coffee and a second colored spoon for general kitchen use. It's such a nice (large) shape you can hold it under a Jolly doser whilst operating the lever.
https://www.ebay.co.uk/itm/Kitchen-Digital-Scale-Measuring-Spoon-500g-Capacity-LCD-Digital-Weighing-Device/282887981434?hash=item41dd70097a:g:hwkAAOSwk4tapfw7
As above, I grind into a ceramic pot, check the weight of the coffee and carefully transfer that via an Orphan Espresso dosing funnel into my portafilter (which is a portafilter stand).
Thanks, just shows with a little ingenuity you can do a decent job without spending a fortune. Yes, I think a stand for the porta filter is useful, especially for my single shot filter that won't balance. I'm soon to give up on the Jolly doser and do a funnel mod. better suited to infrequent dosing demand and allow fine tuning of the grind with less waste. The Jolly porta filter support is on the correct mechanical center, but the aperture spewing out the ground coffee is wide and I get coffee overspill which I don't get dispensing into a spray can 'cup'. It just makes for an unwanted operation to wipe away the overspill and rinse out the cloth. I've got plenty of stainless TIG weld wire, so it won't be too hard to bend something up to fit.
It's taken me a while to get good coffee repeatedly, starting from the worst 12 second single shot for 8 gm and the other end of no liquid pulled through and the alarm going off. But now I've seen that the grind,tamp, and coffee mass are my critical variables, I wouldn't trust an automatic doser to do the best job just yet. I changed the bean type the other day and had to alter the Mazzer grind a couple of stops to get the same pour.
A year late to post on this thread but I just ordered a Garosa weighing spoon from Amazon for £7.39 Same model was £8.99 on ebay. It has the 3 different sized spoons to fit in the one digital handle.
I needed to make an order up to £20 to get free delivery without me being a Prime member (too tight to join and pay out for ever!)
Ordered with XREXS digital dual timer for £12.99. also cheaper than the £16.09 on Ebay although as you know, it's always best to check at least these two sites for different prices.
So I got the two items for £20.38 and free postage!
How do you weigh the output from the grinder with this spoon?
I grind just over the required amount in my entry level Krups GVX2  grinder, using it only to grind for the French Press and the Aeropress.
I then weigh what I've ground straight into the presses on the scales out of the grind chamber, so won't really use the magic weighing spoon for them.?
On my entry level Delonghi Scultura I buy the espresso pre-ground from a local supplier in small quantities to last a week or two, and then vacuum pack it once I get it home. (not in fridge!)
I thought the spoon would be helpful for the bought ground espresso to save weighing on my scales (and spilling in my case!) and then having to transfer again to the filter for the Delonghi.
Also I use the kitchen clock at the moment for timings but I want to tighten the parameters, hence the dual timer purchase.
Meanwhile, dreaming of the Gaggia Classic and a Mazzer!?
Edited by ratty
better explanation
Ok, I've managed to get over my need to buy ground espresso.
Just ordered  the Niche Zero!
I just want a decent machine now.
I'm on the lookout, any suggestions are welcome?
Do you have an idea of what you want to spend ratty? And what kind of use, or drinks, you want to produce?
2019 L-R with hand turned Thuya burr handles and toggles  /  1998 La Pavoni with NickNak single hole steam wand tip  /  Monolith Titan Conical & MAX  / HG-1  /  Kalita wave  /  Stag kettle  /  OCD  /  Joey Skateboard Handle Pullman Big Step & matching stirrer  /  gold B Plus stirrer  /  Push Tamper  /  Puqpress  /  15g & 18g vst  /  IMS 35μM  /  LDT  /  Barista Gear Titanium 12oz pitchers  /  LW Bean Cellars & Caddy  /  Decent thermometer  /  Acme Evo 150ml cups  /  Espazzola  /  Hottop  /  Acme and Loveramics cups /  embroidered by me bar towels  /  coffee bar towel logo embroiderer to the hoi polloi  /  in the cellars: North Star, Foundry, The Barn, HasBean, Coffee Compass  /  6 gorgeous guineas  /  a dog  /  a very lovely and understanding husband
