The EP7 pump only goes to 7 or 8 bar, you need an EX5 or EP5 (perhaps an EK), or an ARS cp15 smart pump (with thermal cutout), these are quieter than Ulka (quite a lot quieter), but check the fitting & mounting, I think it's the same.
Just about to fit the replacement new pump then thought , Do I need any sealant on the pump thread fitting to seal things up = no fluid leaks or go with dry joints ?
Comments ?
ECM Heidelberg Barista Espresso Coffee Machine :coffee:
Eureka Mignon grinder
Plumbers tape if you have any.
SAGE IS NOT A UPGRADE
PTFE TAPE ? the white stuff ?
Yes, loads of it.
Sorry yes,haha
Just re assembled the ECM , switched it on and it is working , The new pump is a lot quieter than the old one ?
Fingers crossed its still working in 5 hours time when it properly warmed up and does not die as it did before
Time will tell :coffee:
On all day Monday and Tuesday , Looks like it was the pump, £14 for the repair , I will drink to that :coffee:
