sandyjmacdonald
First shot pulled with bottomless PF on my Silvia
Yours looks a pretty clean pour, mine has sporting streams at angles, making a bit of a mess!
I grind into my pf, whisk with a mini whisk, tap to level once, and finally, tamp. Is it worth getting something like the ocd distributor?
This looks to me like obvious channelling!
Sage Duo Temp Pro, Niche Zero
Aergrind + Aeropress for travelling
When you say you use a whisk, does it still have the rounded end ? IF it does this can be part of your problem as it does not get into the corners of the basket to break up any small clumps.
Not any more! I cut them off a week or so ago, so I believe it is reaching the corners fine.
Damn that looked so nice!!!
Home 1 -- Melitta Varianza CSP
Home 2 -- Lido 3 & 2012 Gaggia Classic (modded)
Outside -- Porlex mini (modded) & Aeropress
    Advertise with Us
    Get Your Supporter Badge For This Year
