Hi there,
I received my Duetto IV a weekend ago and am very new to the machine. Completely different than my good old Silvia... I am wondering what the noise from the pump is, when it built pressure. It is the high tone which starts just after I turn on the pump, and which stops when it has reached the 9 bar...
What is it - is it normal and is as it should be?
Many thanks, K
[video=youtube_share;Eec_aOFO4qc]
That's the pump drawing in water to refill the system from cold. The boiler level probe then sends a signal to the pump to stop.
The pump will start & stop from time to time, to keep the system topped up.
Notning to worry about !
Thanks for your reply.
I wonder what part in the machine it's as it might be different on the machines. I haven't found any Duetto on youtube which has the same sound. Two times I have been using it, the sound was not there.
Plumbed-in machines usually have a rotary pump (like yours). Rotary pumps are quieter with little vibration.
Machine with integral water reservoirs have a vibratory pump, which ahs a different higher pitched sound.
