Hi, I purchased a Rancillo Rocky on here about 2 years ago. It has served me well up until now. Now I can’t get an espresso grind below level 11 or so.
I have cleaned out the machine twice since this issue first arose. I think the last 2 batches of grindz grinder cleaner messed it up.
I managed to recalibrate as best I could, but couldn’t get the zero point at zero any more. I was helped by a forum member on here twice, who done a FaceTime with me to clean out the machine.
The burrs look just fine, I can’t figure out what the issue is. Think the grinder may need a look at. Would anyone be around South London by any chance? I can compensate somehow, to come over and have a look. Would save me spending any more money on another grinder.
I use this with a 2016 Rancillo Silvia, after 6 seconds on level 11 or so it starts to come out, the speed varies. I was using subscription beans from coffee tasting club, and got some from another source which was freshly roasted within the week, made no difference to the speed, looking to have this dealt with ASAP.
Cheers
Garry
Forget the numbers on the adjustment ring - they don't really mean anything.
Unplug the grinder & empty the hopper & remove it. Empty the grinding chamber.
Turn the adjustment ring (probably anticlockwise) slowly, spinning the motor shaft by hand, until the blades touch.
Then back off the ring by 1/8-1/4 turn.
Fill up with beans, switch on and finetune the grind to achieve your preferred brew time etc.
If you're still getting variable grinds, then a new set of blades may be necessary (not expensive).
Not sure this will work on a Rocky, 1/4 to 1/8 of a turn will be drip range. Doesn't the hopper screw into the top burr carrier?
www.youtube.com/watch?v=I3A6O9cMtmI
The beans are reputable. Also I do have coffee scales and shot glasses, I was using them to weigh what was going in and coming out, I soon got the hang of how much needed to go in, for me to have had to use the scales all the time would be too time consuming, time which I simply did not have or have now. I have used the same amount up until 4 months ago with no issues. I think its the grindz that done it, they got stuck in the grinder as I said, twice. Maybe even it could be my silvia, for a while it stopped dispensing water but we managed to sort that out. All I know is im certain it shouldnt take any more than 5-6 seconds before the coffee starts coming out.
If you reckon there are still some Grindz inside, then unscrew & remove the adjustment ring.
Clean out the chamber with a brush & hoover; clean both threads with a brush & lubricate with a little smear of silicone grease.
Then re-assemble, adjust to find the blades touchpoint & finetune.....
Dependant on how much you have put through the grinder you might be surprised to hear that that burrs on your Rocky could be worn (if you are getting close to chirruping and it still coming out way too fast on the silvia) which can be replaced relatively cheaply OR if you just concerned about where zero is you can always unpeel the number ring to then re stick it in place at the zero marking (chirrup, back off a bit as suggested above)
From memory the burrs were shot at 60Kg on mine and bought a set for £18 from forum sponsor here: https://www.bellabarista.co.uk/50mm-burr-set-for-rocky-grinder.html
Hope of help
Thanks for that that is a great help. I am certain now the zero point is zero, as I was pulsing from 6 backwards and got the loud sound at zero. I ordered a new set of burrs, from ebay at £20 delivered, we had some difficulty getting them off before, either the screws were too tight or we didnt edge the burr carrier to get it off.
I have seen dozens of videos on how to clean out a silvia, I mentioned before there was an issue with the water coming out, which sorted itself, I know this is the grinder forum, hoping there isnt an issue with that. I find it incredibly troublesome and time consuming to clean it out, especially as I only use the machine for espresso
  • 2 weeks later...
