Nopapercup
Help, this is harder than I thought!
Hi Guys and Gals.
I've got my new and first real set up. I bought a La Pavoni Europiccola of Ebay and Ferrari's in Bridgend have just serviced it. I've also bought the La Cimbali Magnum that Grahamg was selling. I went to the local coffee shop that also roasts its beans, had two espresso's yesterday and bought the same beans so I could compare. So this morning up and ready armed with all the gear (clearly no idea) I've managed some terrible coffee.
On my last attempt I had a bit of crema on the sides of the cup and a bit floating but the espresso was watery and bitter. How I set up, 13g in the basket, the pull was 46 seconds don't know if I'm pulling to hard or too slow but this felt comfortable. On the attempt before the grind was half a turn finer and the arm of the machine was bending as I pulled it through coffee was also rubbish.
Any advice would be much appreciated.
You don't mention your output weight?
If grinding 13g it should be approximately 26g of coffee (but this can go up/down when fine tuning taste). It is a good guide to start at a 1:2 ratio.
46 seconds is likely too long and contributing to the bitterness of the coffee, although be aware it can be very difficult to distinguish bitterness from sourness with coffee, especially as you get closer to the right set up for a particular bean.
Watery flavour could be that your output weight is too high, but you need to weigh this to be sure.
There are likely nuances and separate techniques for pulling a shot with a small lever like the Pavoni, plenty of users on here who should be able to advise further, but I think you are aiming for a small thick shot.
Thanks guys I will try coarser. I forgot to measure the output weight until I took a sip and it would have been over 26g. The goal is a short syrupy shot. I'll have another crack when I get back in
Where are you based?
The Artist Formerly Known As 'jonc' | All the gear, almost no idea.
Grind finer. I'm one of those heathens that don't weigh or dose with my lever. However it is rare that I now get a bad espresso. I gauge the amount I grind by eye, tamp firmly insert the portafilter & lift the lever. I now wait for a few seconds, almost a pre infuse if you like, until I see a couple of drops coming into the cup it's then I pull the lever 3 times till I get a cup full. It's always got a good crema & a thickness to it.
Took me about a week to get to producing a good cup so it's worth perusing.
A machine, a grinder & some beans
Weigh input and weigh output , then when you have achieved what you are looking for you have the necessary information to repeat .
Source,Grind,input,time,output,repeat :-)
¿ ǝsǝɥʇ pɐǝɹ ǝuoʎuɐ sǝop
Grind coarser
Grind finer.
Making coffee is the best :rolleyes:
Don't give any advice until we know all the facts :whistle:
@garydyke1
good advice .LOL
good advice .LOL
But did he have all the facts about us not having the facts?
Right just got back and now the grinder won't work. I've put the beans in turned the power on, the light comes on but nothing is happening
Back off the adjuster for the grind as you may have inadvertently jammed some whole or part bean between the burrs if adjusting whilst the grinder not running? if this does not work then can you turn the burrs by hand from the top (power off)?
Roasters: BB Dalian Amazon 1kg -Power contolled GeneCafe 101- 106Kg of greens - Tonino
Thanks John. I've tried loosening the grinder but no joy. I can't get to the burs so I'll unscrew the casing on top and have a look
It's not something silly like the hopper not being in place correctly?
It was something silly. I took the top burr off and everything was fine. I then asked Graham who I bought it from and there's two wires in the doser that need to be connected and they weren't. At least it gave me a chance to re set the dial and take the collar off.
Starting over again I've had two attempts and the grind is too fine. Couldn't even pull the handle down the first time.
New day new go. I adjusted the dial on the La Cimbali Magnum so 0.5 is burrs touching. Last night I tried it at grind setting 7 and I couldn't even pull the handle of the pavoni down so I moved to 10.5 and the outcome wasn't great.
This morning I have set the grind at 11.5, 13g in the basket, 32 second pull with 33g output in cup. Little to no crema and grainy in the cup. Next attempt grind setting 12.5, 13g in basket, 26 second pull and 34.4g in cup. This is what it looks likeIMG_2688.jpg
Tastes about as good as it looks so any suggestions would be much appreciated.
Those ratios are huge, you should be aiming for around 20g from a 13g dose on a pavoni. Go finer still even if you need to put the effort into the pull
AKA Toffee chips
I'm in a similar position experimenting with a pre millennium pav - If this helps I'm trying to vent the false pressure 5secs with the lever partially raised which is giving me around 23g wet from 13g dry, coffee is now slightly ahead of gaggia - just
Ladies and Gentleman I welcome your thoughts ..................
keep calm and grind flat
So I'm well out. I'll go finer and see what happens.
Whilst it does sound like grinding is what you need to get right, I just wanted to check if you're doing the following too;
- Warming the machine up
- Using the lever correctly (Nothing embarrassing about getting it wrong at first)
- Tamping right? Too hard a puck combined with too much pressure from the lever can lead to a channel.
Don't give up hope. I was awful with my first lever machine for a shameful amount of time, and actually first started browsing these forums for advice lol. I cracked it eventually using
My Grinders: Mazzer Luigi, Mahlkoenig Tanzania, Mahlkoenig Vario, Markibar ASPE
My Machines: La Pavoni Professional (customised), Slayer Single Group + Timers, Brewista Smart Pour + Hario V60 Drip Decanter
My Wish List: Stag EKG , Alpha Dominche Steampunk, KVDW Speedster, IKAWA Pro Roaster
Something isn't right. I've gone finer 9.5 on my grinder which gave me an output of 27g then tried 8.5g had to really pull hard to get it through, didn't tamp too hard and got 30g out. I tried 7.5 on the grinder last night and couldn't pull through, could try 8 but would have to hang on it.
I've watched a load of videos on youtube including the SCG one. I'm warming up the machine for 20 min, not sure if I'm using the lever correctly or not. I'm pulling it up, leaving it up between 10 and 20 seconds and then pulling it down which is taking over 30 seconds depending on grind. Trying not to tamp too hard.
That sounds like you're doing it right... Maybe hold it up for slightly less time, and really apply the pressure for a shot? See if it helps?
Personally I have to put my hand on the screw for the boiler to hold the machine down whilst I pull, so I'm applying enough pressure to get a good yield. My girlfriend can't even use it because she finds it too exerting. I'm sure others on here will say I'm being too rough with it, but it's the only way I could get a decent shot comparable to my other machines.
It probably isn't this based on what you've said, (that you got them from a decent place) but is it worth considering the beans aren't great? Have you tried any alternatives? Some freshly roasted beans should be hard to not get crema from..
I got the beans from a coffee shop called the Roastery on Wandsworth Rd in London. They roast on site, I had two espresso in the cafe with the beans and they where roasted 3 weeks ago but they are the only ones I've tried.
