JKK
Expobar Brewtus Variable Pump Pressure Mod
Hello
All this talk of pressure profiling and flow vs pressure.
I thought I should try out a presure/flow control
on the humble VBE pump.
I am using a cheap ([email protected]) variac voltage control
Picture shows bare unit, but I have put the
PCB into a waterproof ABS box.
DANGER NOTE:
THIS MOD INCOLVES MAINS VOLTAGE,
SHOULD ONLY BE CARRIED OUT BY EXPERIENCED
ELECTRICIAN.
Results: ( using EK43 )
Suprisingly effective, gives a much more rounded and three
dimensional taste to the espresso.
Before I was having problems with too much brightness
in the flavours.
Runs at about 18sec on 0-4bar, then I turn up the
dial for 8bar, then slowly back down to 4bar.
Pressure was measured off the Brewtus gauge.
It is perhaps not true pressure profiling, maybe
flow profiling, someone more scientific might
like to chime in . . .
Edited by JKK
spelling !
__________________________________________/////EK43////EXP DB/////
Good work.
i'm looking to drop the flow. But this was interesting.
Ghe sboro fioi!
Nice one. I'd be interested in playing with this mod as well as I also find that my Brewtus shots can be on the acidic side if I'm not careful. At the mo I've got my opv limited to 7bar with a blind basket and tend to downdose by about a gram to get a bit extra headspace for a longer ramp up. I'll be fitting a new 0.5mm gicleur tonight if it arrives today in order to reduce flow some more.
Instagram = @unolonu
Thanks.
Today I tried comparing the pressure profile mentioned
earlier vs a flat 5bar ( that MrBoots discussed in the other expo thread ).
The flow pressure flat profile was better than 8 or 9 bar flat
much less sharp and more chocolate.
But the ramped profile had a better balance of fruit flavours
to chocolate flavours.
Test beans:
Workshop Cult of Done
18.5g > 40g IMS 18 basket
Hello JKK,
great project! It's very motivating to read that you achieved positive results wrt. flavor.
Have you also modified or do you plan to modify the group in order to disable preinfusion?
Best regards,
holgr
Hi
sorry for late reply, just noticed your question.
No, I did look at the idea of disabling it, as featured in the
Rocket 60V, but plumbing is not one of my skills unfortunately.
I wonder if the variac can be connected up to a microprocessor (like a raspberry pi or arduino) to allow it to be controlled automatically over time? Must be possible right? Might need a manual 'Go' switch to make it simpler.
Hi
sorry now for my late reply.
Could you please tell me more about the Rocket 60V? I wasn't aware of the fact that they also disabled preinfusion with that machine.
Hi ZappyAd,
the simplemost solution to that could be to use the Kemo power control unit (Link).
I'm no expert, but it's their variable pressure machine like the Vesuvius.
But the I read somewhere that the rocket uses a stock E61 head, so they disable the preinfusion on it.
