Markymark
Fracino Piccino Help
My Piccino coffee machine has lot's of steam coming out of a valve near the on/off switch and the pressure gauge does not move very much at all.
Does anyone know what might cause this and how to fix it?
I am not sure if it is safe to descale it as it is still in warranty.
I have cleaned the filter which was clogged up but it still has not made it better.
Grateful for any advice.
Thank you!
Mark
You have a leak - best to take the top off and see exactly where the steam is coming from - it is probably just a joint or a seal that needs tightening or replacing! If it is still in warranty, Fracino will get it sorted for you anyway - give Stuart a shout and he would talk you through it if it is fixable at home, otherwise they'll have it back to the factory to fix! Andy
https://thecoffeebean-vanandroaster.co.uk/
[email protected]
Toper Cafemino - Fracino Contempo Dual - Fracino K3 - Piaggio Ape............fresh beans!:)
If my memory serves me well I think a descale is a factory return job.
Ian
Minima ma ma ma Eureka Zenith
It could be that the anti-vac valve on the top of the steam boiler is failing to close. Remove the rear panel to see.
Sometimes a little tap on the plunger sticking out of the middle of the valve will reseat it.
Edited by Norvin
Londinium L1, Compak E8, Gaggia OWC, Kitchenaid Artisan, Bezzera BZ02, ECM Giotto, Gene Cafe 101.
