akostop
Gaggia MDF problem
I've just bought a Gaggia MDF grinder. I've just put in as much beans as needed for one cafe. When all the beans got ground by the grinder, I was expecting (from a previous test-drive with a friend's MDF) to hear only a constant, high-pitch, smooth low noise, which is actually the noise of the grinder's motor. Instead, I also heard some crankier noise (kind of like the one it makes when it grinds beans) on top of the motor noise. Could there be something wrong with my grinder?
thnx
It could be the burrs touching or some residual beans or debris
Try taking off the hopper and tipping the grinder upside down and tapping the base and back to dislodge any items
Then coarsen the grind and run and see if the noise persists
Go finer until you hear the noise (hopefully it has disappeared)
If it comes back you may need to look at the burrs.
well inside the bean holder, it has a thing like, let's say a mushroom, with which the beans get to the burrs from the holes on its side, but on its top its like a plastic circular cap (maybe to avoid putting something large inside maybe?). So I cannot actually see the burrs...sorry :(
To be on the same page here, by bean hopper you mean the big cylindrical container in which we put the beans to be ground? If yes, then no, I cannot remove it (at least without getting some screws out)
Ok - Here's what you need to do:
Empty both the bean hopper and the ground coffee dispenser.
With a small flat bladed screw driver; locate and remove the round rubber/plastic screw caps at the bottom of the bean hopper. Remove the two Phillips head screws covered by the caps.
The hopper should lift off. You can then see what's going on. :)
Lee
Edited by LeeWardle
Coffee consultant, barista trainer & technician based in North Devon!
Email me! Tweet me!
Call me! 07455 188935
