Adams and Russell
Page 184 of 236 FirstFirst ... 84134174180181182183184185186187188194234 ... LastLast
Results 1,831 to 1,840 of 2354
Thread: Decent espresso
  1. #1831
    Join Date
    Jul 2011
    Location
    Kingston Upon Thames
    Posts
    289
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Default
    My lever machine is from the other end of the spectrum to the DE1. I purchased it specifically for its simplicity. However, I'm becoming utterly fascinated by these graphs. Thank you for posting.
  2. #1832
    Join Date
    Aug 2013
    Location
    Byfleet, Surrey
    Posts
    6,069
    Post Thanks / Like
    Mentioned
    471 Post(s)
    Default
    Quote Originally Posted by NickR View Post
    At some point Nick, there will be enough DE1+s around for some properly done blind taste testing against other types of machines with exactly the same coffee using the same grinder calibrated for each machine (e.g. a Niche, because it can easily be adjusted back and forth). That would be an interesting time. In fact I now have 4 different dual boiler machines, so it's something that could definitely be done and others have HX machines they can bring. Who knows, perhaps the lowly HX would win the day?
  3. #1833
    Join Date
    Oct 2016
    Location
    Earth
    Posts
    5,396
    Post Thanks / Like
    Mentioned
    55 Post(s)
    Default
    Quote Originally Posted by DavecUK View Post
    Might as well throw a vintage la pav into the mix for gits & shiggles.
    Will definately be interesting to aee all the comparisons.
  4. #1834
    Join Date
    Aug 2013
    Location
    Byfleet, Surrey
    Posts
    6,069
    Post Thanks / Like
    Mentioned
    471 Post(s)
    Default
    Quote Originally Posted by ashcroc View Post
    For sure......because different people are going to prefer different things as well, which might mean there no such thing as a best machine....just a best machine for "you".
  5. #1835
    Join Date
    Jul 2011
    Location
    Posts
    289
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Default
    For me, a good extraction makes a far greater difference to the taste in the cup than the brew temperature (within sensible limits), which is why I've never been interested in dual boiler machines. However, this is just a theory, I'd love to be able to test it.
  6. #1836
    Join Date
    Aug 2013
    Location
    Byfleet, Surrey
    Posts
    6,069
    Post Thanks / Like
    Mentioned
    471 Post(s)
    Default
    I've tested so many machines now Nick that brew temperature is one of the more difficult things, most people unless they know exactly how to flush their HX machines will struggle to get it even close, then it does make a big difference. Just my experience from a lot of testing tasting and temperature testing in recent years. I'm not saying you can't get good brew temps without a dual boiler, but a well set up dual, just makes things easier.
  7. #1837
    Join Date
    Dec 2015
    Location
    Poland
    Posts
    2,622
    Post Thanks / Like
    Mentioned
    84 Post(s)
    Default
    With the Portaspresso I've also discovered how important the temperature is in connection to roast level...2 degrees Celsius difference can make the (light-roast natural process beans) espresso undrinkable or excellent, other parameters being equal
    MildredM's towels, joey24dirt's tamper, Norvin's dosing ring, Portaspresso Rossa PG Air and HC-P, Kinu M68, Feldgrind, Aergrind, Bellman steamer, IMS baskets, Hario Syphon TC3, Java Maestro dripper, Chemex, French press, Gnali & Zani moka pot, Bonavita kettle & scales, BWT Bestmax Premium
  8. #1838
    Join Date
    Aug 2017
    Posts
    3
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Default
    Is anyone aware of reviews of the decentespresso grinder posted anywhere? I'm getting my DE1+ on Thursday and I don't have an espresso grinder =P (oops...).
  9. #1839
    Join Date
    Apr 2016
    Location
    Hong Kong
    Posts
    951
    Post Thanks / Like
    Mentioned
    24 Post(s)
    Default A cold portafilter affects the shot
    In my previous posting about my "morning espresso" I indicated that my first espresso of the day had a more even infusion temperature than the 2nd one. The reason is that I currently rinse my portafilter out with cold water, and so my 2nd shot has a cooler portafilter than the first (which has been locked into the DE1+ for 30 minutes)
    Attached above are photos of this 2nd espresso.
    You can see that the shot starts about 1.5ºC under temperature. The DE1+ then tries to quickly compensate by putting in slightly-hotter-than-goal water. This causes the infusion temperature to 0.75ºC slightly over at 15 seconds into the shot, before it settles in at 0.3ºC over temperature for the last 7 seconds of the shot.
    Obviously, still very good temperature results, just not as perfect as a fully warmed up portafilter.
    A goal I have with this tablet software I've written, is to help you improve your barista skills, by seeing the effects of your actions.
    For comparison purposes, here's the temperature line on my 1st espresso of the day.
  10. #1840
    Join Date
    Jan 2018
    Location
    Posts
    1,629
    Post Thanks / Like
    Mentioned
    22 Post(s)
    Default
    Not forgetting a Puqpress.
    Jon.
    One Life this is it, it's not a rehearsal so enjoy it best you can - Have some fun, buy a coffee machine.
    ECM Synchronika - ECM V-Titan 64 Grinder - AMIR Scales and they work fine - 15-18-20-22-25g VST Filter Baskets - Several Jugs and a Home Made Knock Box. - Useful contributions from the Family.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Decent Espresso
Important Site Information
Google Analytics Alternative
