Rave Coffee Roasters
Page 178 of 231 FirstFirst ... 78128168174175176177178179180181182188228 ... LastLast
Results 1,771 to 1,780 of 2305
Thread: Decent espresso
  1. #1771
    Join Date
    Sep 2017
    Posts
    50
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Default
    If you see that it's dirty, then yes, you should clean it. The metal around that probe is 0.5mm thick stainless steel, for fast response, so obviously you shouldn't scrape at it with a screwdriver. An abrasive sponge and a cleaning product should be fine (it's not that delicate, owing to its strong shape).
    I look forward to learning more from our customers about what works, for cleaning and many other topics.
    Yes, we do sell our own gaskets, here:
    https://decentespresso.com/cart?s=70008+1
    note that the price is a bit more expensive than others, because shipping from HK has to be accounted for by us.
    You're welcome to use any 8.5mm gaskets (NBR or Silicone, as you wish) from any source you like, as we are completely compatible with the standard. Before we made our own, we were using Simonelli NBR gaskets, and Cafelat silicone gaskets.
    Note that one reason we put the group head handle on is to tempt people to not over-tighten the portafilter, which baristas often do by leaning into the handle with all their body weight. Less muscle when locking in the portafilter will greatly extend the life of your gasket.
    -john
    Great news! A year or so ago I ended up buying 20+ Cafelat 8.5 silicone gaskets. Excuse me for the off-topic.
    Now for the real question. Do you have any idea of how many shots did this machine that Shin showed us had prepared? Have you tried other kinds of shower screens?
    Also, if you change the shower screen to something more restricted (Like an IMS competition), will that affect flow rate?
    Thank you John for all the information you keep posting.
  2. #1772
    Join Date
    Dec 2015
    Location
    Poland
    Posts
    2,612
    Post Thanks / Like
    Mentioned
    83 Post(s)
    Default
    -john
    girls at work do this all the time
    MildredM's towels, joey24dirt's tamper, Norvin's dosing ring, Portaspresso Rossa PG Air and HC-P, Kinu M68, Feldgrind, Aergrind, Bellman steamer, IMS baskets, Hario Syphon TC3, Java Maestro dripper, Chemex, French press, Gnali & Zani moka pot, Bonavita kettle & scales, BWT Bestmax Premium
  3. #1773
    Join Date
    Sep 2017
    Posts
    50
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Default
    Quote Originally Posted by Stanic View Post
    Just do as I did. Tell them to ask you to prepare their coffees. At least now I know how clean the machine is, I have the grinder correctly set up, etc... And the plus is you are the favourite of all those cuties LOL.
  4. #1774
    Join Date
    Dec 2015
    Location
    Poland
    Posts
    2,612
    Post Thanks / Like
    Mentioned
    83 Post(s)
    Default
    Quote Originally Posted by Andreugv View Post
    Lol you've got to be kidding me, they don't care and as the owner doesn't either, I don't care what they do with the machine and grinder at all I grind my own beans with the Feldgrind, no crappy robusta miscela for me
    They might be cute but actually are stupid as a boot as they say in polish...I've asked them on April the 30th what celebration day is it tomorrow, they didn't have a clue..blimey
  5. #1775
    Join Date
    Oct 2013
    Location
    Berks
    Posts
    6,828
    Post Thanks / Like
    Mentioned
    145 Post(s)
    Default
    Sounds like they need help... Mayday!
    _______
    Eat, drink and be merry
  6. #1776
    Join Date
    Dec 2011
    Posts
    6,849
    Post Thanks / Like
    Mentioned
    98 Post(s)
    Default
    I know there is such a thing as 'May Day' - but honestly if you asked me that question on the 30th I also would have given you a blank stare - it not exactly a notable date for me or anyone I know, even if it has some significance to some folks.
  7. #1777
    Join Date
    Jan 2018
    Posts
    21
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Default
    Of course soon hopefully some of us will be explaining what DE day is and what an unboxing is to completely oblivious people.
  8. #1778
    Join Date
    Dec 2015
    Location
    Poland
    Posts
    2,612
    Post Thanks / Like
    Mentioned
    83 Post(s)
    Default
    I don't expect everyone to know everything but if it is a bank holiday which is quite international I find it baffling that people who work in business affected by it don't know what's going on..I'm not sure what level of significance does it hold in the anglo-saxon world nowadays and of course you can ignore anything but still..blimey
  9. #1779
    Join Date
    Sep 2017
    Posts
    18
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Default
    Cleaning group head:
    1. After how many espressos do you expect a home user would be advised to clean the group head parts?
    2. Have you evaluated the feasibility of smaller holes in either the lower or middle diffuser to reduce the amount of coffee grounds migrating upward? Minimizing migration to the top diffuser seems especially desirable since it requires 4 screws to remove.
    Since the bottom diffuser is thin, perhaps it could have a larger number of smaller diameter holes, like a filter basket.
    Perhaps the middle diffuser, being thicker, could have conical holes, with the narrow end down. The conical shape would permit a smaller diameter outlet to block coffee without proportionately increasing impedance to water flow — like the VST basket holes, but inverted.
  10. #1780
    Join Date
    Jul 2017
    Posts
    62
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Default Decent espresso
    @ Bob Stern:
    You cannot avoid the group getting dirty as it is from coffee oils/fat mainly - not from particles moving up!
    Cleaning interval was mentioned by John: once the water comes out uneven.
    Best
    Stefan
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Coffee Omega EK43 Grinder
Important Site Information
Google Analytics Alternative
