Maintenance: is very easy. The entire top burr and shaft thing can drop down from the brace by unscrewing the adjust dial all the way without resting a sweeper arm on part of the brace (probably sounds complicated but when you actually see inside you'll understand exactly). Peter includes a nice little brush to clean things.
Fit and finish: The wood is absolutely beautiful but you need to expect at least some natural blemish in the wood, just a feature sometimes. The metal parts look brilliant as well. I wouldn't personally get a metal bottom though. Peter also includes a few extra rubber washer for the grind cup thing just in case it wears down over time.
Grind quality: I've done mostly v60 and a few cafeterias and just impressed impressed impressed all the way.
Stability of adjustment: this is a very very slight concern of mine, even with the rubber washer in place below the nut there is a tidy bit of slip of settings (maybe half a setting from one whole number to another). I'm not sure about other hausgrind owners but in the end it isn't a big deal and I'm pretty sure it stays in place while grinding. The slip is only noticeable when gently twisting dial with fingers.
Wood movement: No change in wood fitting. Its a very tight and reassuring fit.
Zero: can't answer this one as I lost all my grind reference points when accidentally fitting new enamel dial in the wrong alignment!
I'm just completely happy. Peter rates the burrs for a very long time based on daily home (or office) usage. Hopefully someone with a better grasp of English than me can write an excellent review when batch 2 goes out
Bookmarks
